Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 2640 rebuild
Tx Jim
02-20-2013 04:58:28
Can't isn't a good word but replacing balancer brgs with engine on an engine stand would be a lot easier IE the rear brgs would be a booger to replace with engine in the tractor.
Tim S
02-20-2013 06:00:32
 Re: 2640 rebuild in reply to Tx Jim, 02-20-2013 04:58:28
You "Can't" get the rear bearing out while it's in the tractor...also check your clean air connections ,if it is drawing dirty air in on the clean side it will break all the top rings,,quickly,,I use ether and spray around the pipes to check them, if you have a leak the rpm's will pick up.
