Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: model b pistons questions
[Return to Forum]
warren woodrow
02-19-2013 19:59:23
107.194.190.201
Finally got pistons out of my 1941 model B . Serial # 102048 . I have one bad cylinder which I believe will require a maximum overbore . Is the maximum .125 and is that 4 11/16 inches . Some on this board have said that a late model B piston will fit .125 overbore and pistons will fit my rods and pins . Is this all correct as I am ready to take it to a machine shop.
[Reply]   [No Email]
JD Man MI
02-20-2013 15:01:30
174.124.224.207
 Re: model b pistons questions in reply to warren woodrow, 02-19-2013 19:59:23
Use late B pistons, I've done it and it works great
[Reply]  [No Email]
MSD
02-20-2013 08:41:51
71.209.114.142
Can you reuse the old pistons or do you have something else in mind? It might be cheaper to sleeve it and use the original pistons than boring it and putting new ones in. Last A we did it was $50 for the sleeve installed plus boring charges.
[Reply]  [No Email]
warren woodrow
02-20-2013 11:34:29
74.231.185.160
 Re: model b pistons questions in reply to MSD, 02-20-2013 08:41:51
Machine shop I contacted said $700.00 to sleeve and bore both cylinders. Needless to say I will contact others. Always someone wanting to make a killing....... instead of a living.
[Reply]  [No Email]
warren woodrow
02-20-2013 10:16:53
74.231.185.160
Had been led to believe sleeving was alot more expensive. I think my pistons are good and at that price range I would rather sleeve and use my originals.
[Reply]  [No Email]
gtx1967jewison
02-20-2013 14:05:47
174.253.145.165
 Re: model b pistons questions in reply to warren woodrow, 02-20-2013 10:16:53
New ones are half the weight, more compression/power, barely more than the cost of rings for your worn originals. To sleeve it requires boring much farther than it does with new pistons. Its always cheaper to buy pistons & bore than buy rings bore sleeve & finish bore the sleeve. & a much nicer outcome imo.
[Reply]  [No Email]
gtx1967jewison
02-20-2013 04:45:02
174.253.145.165
These things have alot of iron in them. As an example, no pistons are available for a model R so they are often bored 375 thousandths! Thats 3/8". To use 720/820 pistons. I would call Ray at Extreme Tractor Parts or Josh Blackburn. They both have built alot of these & both make custom pistons. I believe you can use Late B pistons. Get some new aluminum ones. They are both on the pulling forum often.
[Reply]  [No Email]
Mike n Mo
02-19-2013 20:31:16
72.161.211.171
A 1941 B would have had a stock bore of 4.5", so a late B standard bore piston would require an overbore of 3/16" (4.6875"). This should work ok unless the block has excessive rust pitting on the water side of the cylinders. I've read on this forum that .125" over pistons (4.625") aren't available for the early styled B's, but I've never researched that myself. Just passing along the hearsay. I think I would have the pistons before having the block machined. You can always return the un-used new pistons, but you can't undo the machining done on the block. Good luck with your project. Mike
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
