| John Deere Tractors Discussion Forum |
Topic: Re: 2640 rebuild
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| FrankinFla
02-19-2013 18:21:25
70.196.128.117
The 2640 uses a 4 cylinder engine with 2 balance shafts. The bearings the shafts run in should be replaced. Replacement requires removing the balance shafts. Not replacing the balance shaft bearings can be the reason for low oil pressure after a rebuid and can lead to major block damage when worn bearings spin in the block. |
[Reply] [No Email] | |
| Albert F
02-19-2013 19:27:03
72.173.79.43
Re: 2640 rebuild in reply to FrankinFla, 02-19-2013 18:21:25
| Can the bearings for the balance shafts be done in frame or does it require a complete removal? |
| Tx Jim
02-20-2013 04:58:28
67.142.163.27
Re: 2640 rebuild in reply to Albert F, 02-19-2013 19:27:03
| Quoting Removed, click Modern View to see
Can't isn't a good word but replacing balancer brgs with engine on an engine stand would be a lot easier IE the rear brgs would be a booger to replace with engine in the tractor. |
| Tim S
02-20-2013 06:00:32
68.75.29.193
Re: 2640 rebuild in reply to Tx Jim, 02-20-2013 04:58:28
| You "Can't" get the rear bearing out while it's in the tractor...also check your clean air connections ,if it is drawing dirty air in on the clean side it will break all the top rings,,quickly,,I use ether and spray around the pipes to check them, if you have a leak the rpm's will pick up. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
