Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: JD 630 oil slinger
[Return to Forum]
jturbo10
02-19-2013 13:42:28
67.232.120.65
My 58 JD 630 has slung oil out of the fly wheel side since I got it about 9 years ago. Have a brand new shop now and I can't live with the oil drippings when I drive it on the shop apron and inside so I end up with card board everywhere. I looked at my parts book to identify parts that likely should be replaced. My local JD dealership don't really know much about 2 cylinder tractors so they could not give me any advice on what parts I really needed to fix the problem. I did order the following parts/key:
1. A4400R/10 gasket
2. A4224R/12 packing
3. D2009R/13 spacer drive pin
We could not figure out if AA5409/11 spacer was needed or not. (It subs to A3324R,with packing)
A3324R lists for $277.98 so I don't want to order it if not needed as Mother Deere won't take it back. I don't skimp on parts but I don't want to throw away $278 either.
Has anyone done this repair and can give me some advice on parts usually needed and some hints on repair issues. Any recommendations would be appreciated. I'm getting the tractor ready for a tractor cruise our antique club is planning for May and I don't want to be dripping lots of oil.
[Reply]   [No Email]
Mike M
02-20-2013 06:06:58
24.140.0.120
 Re: JD 630 oil slinger in reply to jturbo10, 02-19-2013 13:42:28
Make sure to use feeler gauges or shim stock and center the outer cover around the slinger as you tighten it up.
[Reply]  [No Email]
mbdeere
02-19-2013 16:09:14
184.63.147.142
you probably only need part 10 and part 12 on the parts diagram in the parts catalog. your drive pin is probably ok. on the one I just did today also needed part 20, some how mine was cracked. It all will probably cost you about $20.00 total for the two parts.
[Reply]  [No Email]
jturbo10
02-19-2013 18:43:26
67.232.120.65
 Re: JD 630 oil slinger in reply to mbdeere, 02-19-2013 16:09:14
I looked up part key 20 (thrust washer) and noticed Mother Deere wanted over $50 for it. It must be some special washer. At least we can still get some of these parts for restoration.
[Reply]  [No Email]
Mark-Ia
02-19-2013 14:43:31
207.177.117.7
You shouldn't need the spacer. Might not need the drive pin if it's not chewed off. they are just driven in with a hammer. Should come out with a vice-grips. If not just drill it.
[Reply]  [No Email]
jturbo10
02-19-2013 15:48:33
67.232.120.65
 Re: JD 630 oil slinger in reply to Mark-Ia, 02-19-2013 14:43:31
Thanks Mark. Do you know what acts as the seal? I will also check the oil drain to be sure it is not plugged and keeping oil up against the slinger.
[Reply]  [No Email]
Mark-Ia
02-19-2013 17:10:13
207.177.117.7
 Re: JD 630 oil slinger in reply to jturbo10, 02-19-2013 15:48:33
#12 is the square type packing used for the crank seal.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
