Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
John Deere 70D Pony Motor bearings
JMG
02-19-2013 13:12:44
Hi all, Having trouble finding main bearings for pony motor main bearings and thrust washer.(Thrust I can have made if needed)
WeirdDeere
02-20-2013 03:55:27
 Re: John Deere 70D Pony Motor bearings in reply to JMG, 02-19-2013 13:12:44
There are early engines with small main bearings and late engines with larger main bearings, but just to confuse the issue there was an update kit that would put a new crank in an early engine...it had one small main bearing to fit the block and one larger bearing. My 70 diesel has it and was a little confusing til I read the parts book closer.
Brandon
gtx1967jewison
02-19-2013 19:30:40
H&J machine in Carrington nd. Has cam, crank, rod bearings. Cheapest out there. Perfect quality, great guy. Bonafide 2-cyl virus carrier...
jmg
02-19-2013 19:43:21
 Re: John Deere 70D Pony Motor bearings in reply to gtx1967jewison, 02-19-2013 19:30:40
"Bonafide 2-cyl virus carrier"..... Funny stuff. No known cure!
Thanks for the info!
John-cummins
02-19-2013 18:45:54
Was told the 730 pony had the bigger mains
Mike n Mo
02-19-2013 13:45:39
Murphys Motor service has pony motor main bearings available. Don't know about the thrust washer though. Hope this helps, Mike
jmg
02-19-2013 19:47:23
 Re: John Deere 70D Pony Motor bearings in reply to Mike n Mo, 02-19-2013 13:45:39
Thank you!
Mike M
02-19-2013 13:21:51
From what I remember those V4 ponies all had the same rods. The mains were changed at some time and the size changed. 2 different cranks also because of the main brg. size change.
Blksmok
02-19-2013 18:19:44
 Re: John Deere 70D Pony Motor bearings in reply to Mike M, 02-19-2013 13:21:51
When the black dash 720 diesels were introduced the pony engines were also changed and had s/n plates on them. The difference between early pony engines and later ones are : bigger pushrods/lifters/rockerarms, thermostats and water pump bypass tubes , larger main bearings and thrust washers and different linkages in the transmission plus a few other minor changes.
jmg
02-19-2013 19:46:38
 Re: John Deere 70D Pony Motor bearings in reply to Blksmok, 02-19-2013 18:19:44
That would explain the 4 pushrods that resemble bananas. I think I'll keep the throttle speed down around 4000 rpm. Think it will produce enough juice? I live in CA where below 20 degrees is very rare....
Mike M
02-20-2013 06:17:19
 Re: John Deere 70D Pony Motor bearings in reply to jmg, 02-19-2013 19:46:38
Neighbor had one that had some of those "bananna" pushrods along with broken rocker arm shaft. Had to of killed off a couple of cylinders. Funny thing was it would still start the diesel engine up !!! Just stuck some used good parts back in it and kept going.
JMG
02-19-2013 13:16:00
Oh, and I usually get asked if its an early or late pony. Tried searching for those differences, and from what I gather, it's just the rod's???? Or are htey referring to the R pony which is obviously different....
730d se
02-19-2013 17:03:34
 Re: John Deere 70D Pony Motor bearings in reply to JMG, 02-19-2013 13:16:00
Early pony has no serial number tag, late pony has a tag.
Kent Petersen
02-19-2013 16:36:57
no what they are talking about is the crankshaft main brg. it is larger diam. on the flywheel end on the later engines
