JohnDeereM50
In the process of getting the M setup so it will pull plow properly. I have back wheels set to spacing listed in plow operators manual. The front end is adjusted out one notch and I want to move it all the way in so inside of front tires are even with inside of back tires.
Are the tie rod ends supposed to be bent like this? Both sides are like that. They won't budge I'll probably need new ones I reckon. They are bent at the ends also.
