pbb
Does any one use TSC 15-40? Will it do the same is Rotella?I was in the store looking at the oil and TSC oil is about 20 dollars cheaper for 5 gal than Rotella.I figger i would get some imput on it before i gave it a try.I just use my tractor for parades and rides.I know a farmer that uses Walmart 15-40 in all his stuff.
I would say in a parade tractor it would be fine. I myself wouldn't use it in a field tractor and It might be just as good as other brands of oil but I don't want to find out that it isn't You will probably change the oil in that parade tractor long before the oil ever wears out.
That oil is a bunch better than what was on the market when your tractor was built. I wouldn't worry about it.
