TractorLinks.com
Show Parts for Model:
Re: 830 Power Steering
mrjdman80
02-17-2013 11:14:27
If the steering works, then no air issue. Heat means resistance. Either metal on metal, but if the suction line is hot it could be back feeding. How worn are the gears? What did you use to seal between the pump housing pieces? If you used something to thick then it will bleed back. Tim
Toby Harter
02-18-2013 14:45:01
 Re: 830 Power Steering in reply to mrjdman80, 02-17-2013 11:14:27
I didn't use anything to seal between the pieces as there was nothing used between them when I took it apart. The gears seemed fine in them but I'm going to take it back apart and see what's going on.
