(quoted from post at 07:51:33 02/18/13) It sounds like power shift transmissions are getting expensive to rebuild Do the cowl, dash, hydraulic valves, etc. have to be changed also?
(quoted from post at 17:33:20 10/02/17)
Seems like a John Deere kit with the crate under the motor exactly like in the picture above. Very interesting. Engine is probably a 6068 Turbo.
(quoted from post at 11:52:09 10/03/17)
6068 engine would have starting motor on RH side not LH side.
(quoted from post at 03:52:09 10/03/17)(quoted from post at 17:33:20 10/02/17)
(quoted from post at 08:47:42 10/03/17)(quoted from post at 03:52:09 10/03/17)(quoted from post at 17:33:20 10/02/17)
It is for sure a 6068 because lower side of block has bulges that the 6059 does not have. 6059 is pretty round on the side.
Plus the exhaust manifold is not from a 6059 area.
