4020 cooling
I had an M&W seven blade fan & matching shroud on my 4020 and wasn"t very happy with it. The M&W fan was 19", the original 4020 fan is 21". I now have a 6 blade 21" fan from a 2940 and am using the original 4020 fan shroud. I also am using a water pump pulley from a 4010 which is smaller in diameter, increasing the fan speed. The 2940 fan throws more air than the M&W did.
There were some combine fans that some used.The best way we have found to eliminate cooling problems has been to have radiator checked out.
