4010 diesel will not crack back up
Mtractor
I got traded a 4010 diesel tractor went to look at it cranked right up had not just been running I felt of the block and oil and the muffler. Went back several hours later to pick it up it cranked right up. Got it home it sat on my trailer over night went to it the next morning and now nothing it turns over great but will not start. I gave it a shot of starting fluid and it did not even fire . There is no air in the system i get diesel out at every injector. Plenty of diesel in it. Why will it not start back up. Why will it not fire on starting fluid I sprayed it right into the intake.It does not even act like I am even spraying any in there. What could have happened .
It's possible that the fuel valve in the injection pump isn't allowing fuel to be pumped to injectors. I don't like to use ether so I'd suggest to try and "tow" start the engine.
Are your cranking RPM's low?
Plug it in if it has an engine heater and throw a battery charger on it overnight and try again.
is the pull shut off knob and cable on the dash releasing the throttle lever does not shut the fuel off ,,,,,,,,,,,try pulling throttle lever all the way wide open when you crank it if she starts shove it back to idle
I have tried it in all positions with no luck . I have pulled the shut off cable out and tried it as it cranks over pushing it back in still nothing. I have tried the throttle in all positions still nothing . Thanks
Does it smoke when you are cranking the starter? If no smoke you have a fuel problem. Remove the tach cable and see if the tach drive turns with the engine.
Collapsed Mouse nest in air filter cleaner,It should have at least fired on starting fluid.Check to see if cam is turning and operating valves
Come to find out my fuel pump was not working properly . Changed it I can get it to fire now on a small shot of starting fluid now all is left is to bleed the system out.
