Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 4010 diesel will not crack back up
[Return to Forum]
Mtractor
02-15-2013 13:33:07
174.225.21.194
I got traded a 4010 diesel tractor went to look at it cranked right up had not just been running I felt of the block and oil and the muffler. Went back several hours later to pick it up it cranked right up. Got it home it sat on my trailer over night went to it the next morning and now nothing it turns over great but will not start. I gave it a shot of starting fluid and it did not even fire . There is no air in the system i get diesel out at every injector. Plenty of diesel in it. Why will it not start back up. Why will it not fire on starting fluid I sprayed it right into the intake.It does not even act like I am even spraying any in there. What could have happened .
[Reply]   [No Email]
Mtractor
02-21-2013 13:07:32
174.225.7.197
 Re: 4010 diesel will not crack back up in reply to Mtractor, 02-15-2013 13:33:07
Come to find out my fuel pump was not working properly . Changed it I can get it to fire now on a small shot of starting fluid now all is left is to bleed the system out.
[Reply]  [No Email]
algar
02-16-2013 05:06:28
199.224.114.66
Collapsed Mouse nest in air filter cleaner,It should have at least fired on starting fluid.Check to see if cam is turning and operating valves
[Reply]  [No Email]
Cliff Nelson
02-15-2013 19:17:08
69.21.97.161
Does it smoke when you are cranking the starter? If no smoke you have a fuel problem. Remove the tach cable and see if the tach drive turns with the engine.
[Reply]  [No Email]
Determined
02-15-2013 19:05:25
216.130.212.234
Whats the temperature where you are at?
[Reply]  [No Email]
silverado
02-15-2013 17:57:07
205.188.116.133
is the pull shut off knob and cable on the dash releasing the throttle lever does not shut the fuel off ,,,,,,,,,,,try pulling throttle lever all the way wide open when you crank it if she starts shove it back to idle
[Reply]  [No Email]
Mtractor
02-15-2013 18:40:58
174.241.11.52
 Re: 4010 diesel will not crack back up in reply to silverado, 02-15-2013 17:57:07
I have tried it in all positions with no luck . I have pulled the shut off cable out and tried it as it cranks over pushing it back in still nothing. I have tried the throttle in all positions still nothing . Thanks
[Reply]  [No Email]
Determined
02-15-2013 17:24:18
216.130.212.234
Are your cranking RPM's low?
Plug it in if it has an engine heater and throw a battery charger on it overnight and try again.
[Reply]  [No Email]
Mtractor
02-15-2013 18:37:40
174.241.11.52
 Re: 4010 diesel will not crack back up in reply to Determined, 02-15-2013 17:24:18
It turns over plenty fast it is still 24 volt.
[Reply]  [No Email]
Tx Jim
02-15-2013 13:44:09
67.142.163.20
It's possible that the fuel valve in the injection pump isn't allowing fuel to be pumped to injectors. I don't like to use ether so I'd suggest to try and "tow" start the engine.
[Reply]  [No Email]
larryanderson
02-15-2013 15:21:17
184.21.172.50
 Re: 4010 diesel will not crack back up in reply to Tx Jim, 02-15-2013 13:44:09
This would be too easy. But is it possible that throttle is in shut off position?
[Reply]  [No Email]
Mtractor
02-15-2013 15:36:00
174.225.21.194
 Re: 4010 diesel will not crack back up in reply to larryanderson, 02-15-2013 15:21:17
Nope checked that . Thanks
[Reply]  [No Email]
Mtractor
02-15-2013 15:38:13
174.225.21.194
 Re: 4010 diesel will not crack back up in reply to Mtractor, 02-15-2013 15:36:00
I did not spell crank right I just caught that sorry
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
