420/430 Power adjust wheels
I have posted a set of what I thought to be 420 430 wheels. A fellow called about them and said he had noticed they only had 8 holes and his had 9. Are they not JD wheels, they were JD yellow when I picked them up, but I guess that doesn't mean a lot. If you would check my ad in photo parts and see what you think, the post was a couple days ago.
Thank you.
Charlie
Charlie. Well are these 24" or 28"? I have a 40S and a 420S and they have 24" power adjust wheels with 6 lug bolts. Then I have a 430W and a 430T with 28" power adjust wheels with 8 lug bolts. I have a 40W with 28" pressed wheels with 9 lug bolt and a 420T with 34" pressed wheels with 9 lug bolts. So I believe you John Deere 28" power adjust wheels listed. Tom in French Village.
(quoted from post at 19:32:36 02/14/13) I have posted a set of what I thought to be 420 430 wheels. A fellow called about them and said he had noticed they only had 8 holes and his had 9. Are they not JD wheels, they were JD yellow when I picked them up, but I guess that doesn't mean a lot. If you would check my ad in photo parts and see what you think, the post was a couple days ago.
Thank you.
Charlie
My 1958 420W only has 8.
