TractorLinks.com
Show Parts for Model:
Re: Electrical Tape on a Steering Wheel
Randy G
02-14-2013 19:24:38
Take a razor knife around the outside of the steering wheel and cut the tape. Peel it off. Careful not to slip. Cuts hurt!
SuperABen
02-15-2013 17:40:43
 Re: Electrical Tape on a Steering Wheel in reply to Randy G, 02-14-2013 19:24:38
Thanks for the tips. The problem is that the vinyl is sun dried to where it won't peel, just snaps and breaks. This M sat outside for awhile.
I was hoping for something that could dissolve the glue but not burn up the steering wheel's rubber.
Ben W.
Lee B
02-16-2013 01:45:28
 Re: Electrical Tape on a Steering Wheel in reply to SuperABen, 02-15-2013 17:40:43
WD-40 is a tremendous solvent for that type of stickem, trouble will be that it can't get thru the layers of vinyl to soak the bottom layer good. But with the cut around the circumference done, there might be enough cracks in the old rubber to let enough in there to do a fair job of it. I'd let it soak for at least a day. It shouldn't harm the rubber at all, but could make it messy handling until it dried off.
Fixerupper
02-15-2013 20:00:31
Heat gun like was mentioned. If the glue is a problem after the tape is off, paint-prep or any alcohol based pre-paint cleaner will get the glue with enough soaking and scrubbing. Jim
4020guru
02-14-2013 20:38:24
Apply some heat to the tape with a heat gun .
