| Author |
[Modern View]
| SuperABen
02-14-2013 18:07:17
184.63.130.244
I'm rescuing an M that has electrical tape strapped around the steering wheel as a poor man's grips. Baked on. What is the best way to get it off? If I can unwind it I will do so, but if not, what options do I have? Thanks! Ben W. in VA OldPathsEquipment.com |
| Ken11487
02-17-2013 17:38:44
64.66.236.64
Re: Electrical Tape on a Steering Wheel in reply to SuperABen, 02-14-2013 18:07:17
| What was the name of the rubber spray or what was the intended use for it.?
Maybe the rubber sone guard stuff???? |
| PecosAllis
02-18-2013 05:54:07
67.54.134.122
Re: Electrical Tape on a Steering Wheel in reply to Ken11487, 02-17-2013 17:38:44
| OK Ken the suff I used was called OUTLAST from Lawson Products (1-800-LAWSON4U)or Drummond a Heavy-Duty Black Rubber coating. It is about 8 dollars from my Lawson salesman. I only used about 1/2 can. This stuff like bubbles/boils when you spray it and it fills in the fine to medium cracks.. It dried completely and is not sticky. A like product (I have not used it) is sold at the big box store as a rubber sealing spray the commercials on TV show a guy spraying a screen door making it water proof. Good Luck |
| clampdaddy
02-15-2013 19:01:39
50.8.151.226
| I would think that if someone wrapped the wheel in tape it was probably cracked or worn out. |
| Texasmark1
02-15-2013 06:35:41
198.45.243.137
| | Not aware of your financial resources, but the NH dealer has some nice wheels with center caps and all for what I consider a reasonable price......if you can stand the NH rather than Ford logo on the cap. Grin. Also for the current replicas of the old Ford spoke wheels, Stephens Tractor Parts near Alexandria, LA. has some with molded rims that are better than the original. Mark |
| PecosAllis
02-17-2013 05:42:11
67.54.134.122
Re: Electrical Tape on a Steering Wheel in reply to Texasmark1, 02-15-2013 06:35:41
| Well I didn't have much resources available at the time when I had to redo a steering wheel. After I took all the junk off of it I saw that it was very badly cracked and chunks missing. I cleaned the cracks up and got that puddy for rubber or steel repairs and filled them in. Once hard I took off all the rough edges and formed the grips and wheel as it once was. I taped up the steel spokes and got a can of that spray rubber stuff at the Big W store and sprayed the wheel another coat and it is amazing all the fine cracks and uneven areas just evened out and now that steering wheel is as good as new. been using it now for 5 years no cracks and it has good grip. |
| Hugh McKinney
02-15-2013 08:13:44
75.104.206.93
| They are indeed near Alexandria, but the actual town is Coushatta, Louisiana, in case someone wants to google it for the number. They are top notch folks. |
| Texasmark1
02-15-2013 06:36:59
198.45.243.137
| | Oops!!!!!! Sorry green. Forgot that I had moved on from the blue site. My sincerest apologies. Mark |
| Jethro Lilley
02-15-2013 18:04:09
70.192.202.63
Re: Electrical Tape on a Steering Wheel in reply to Texasmark1, 02-15-2013 06:36:59
| That's ok, Tex, I've seen green tractors painted with cheap paint turn blue. |
| Randy G
02-14-2013 19:24:38
71.7.62.188
| Take a razor knife around the outside of the steering wheel and cut the tape. Peel it off. Careful not to slip. Cuts hurt! |
| SuperABen
02-15-2013 17:40:43
184.63.130.244
Re: Electrical Tape on a Steering Wheel in reply to Randy G, 02-14-2013 19:24:38
| | Thanks for the tips. The problem is that the vinyl is sun dried to where it won't peel, just snaps and breaks. This M sat outside for awhile. I was hoping for something that could dissolve the glue but not burn up the steering wheel's rubber. Ben W. |
| Lee B
02-16-2013 01:45:28
64.37.30.36
Re: Electrical Tape on a Steering Wheel in reply to SuperABen, 02-15-2013 17:40:43
| WD-40 is a tremendous solvent for that type of stickem, trouble will be that it can't get thru the layers of vinyl to soak the bottom layer good. But with the cut around the circumference done, there might be enough cracks in the old rubber to let enough in there to do a fair job of it. I'd let it soak for at least a day. It shouldn't harm the rubber at all, but could make it messy handling until it dried off. |
| Fixerupper
02-15-2013 20:00:31
100.42.82.30
| Heat gun like was mentioned. If the glue is a problem after the tape is off, paint-prep or any alcohol based pre-paint cleaner will get the glue with enough soaking and scrubbing. Jim |
| 4020guru
02-14-2013 20:38:24
216.226.89.76
| Apply some heat to the tape with a heat gun . |
