Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: JS 60 Clutch
[Return to Forum]
John Shanahan
02-14-2013 17:37:20
98.215.108.119
I just finished rebuilding the clutch on a 1955 60. New facings, sliding drive disk, new disk with riveted facings, new bearing, new t bolts. I have about an 1/4" play in the pulley between disengage and engage when the engine is off. Seems like a lot?.?.? I put new thrust washers on the crank and have about 0.005" crank play. In addition, wwith the engine off, it spins free, when I start the engine it locks up and I can not stop the pully with the pully brake? What did I do wrong????
[Reply]   [No Email]
Mike M
02-15-2013 13:33:25
24.140.0.120
 Re: JS 60 Clutch in reply to John Shanahan, 02-14-2013 17:37:20
Those 60 models are VERY touchy on the clutch as to how much free play you end up with between the clutch being disengaged and the back facing starting to get pinched again trying to keep driving as you pull the lever back.Most other models a simple pulley brake adjustment takes care of this.
A clutch driver disc that is setting back too far on worn splines will make them darn near impossible to get working right.
Ideally the end of the crank should set back inside of the driver at least 1/4" the more flush gets the worse it gets.
I have had to turn some material off the backside of the clutch driver and use a thin facing to try and get them working better without binding up wanting to keep on driving.
[Reply]  [No Email]
Maark
02-15-2013 10:49:26
207.177.117.7
Your excessive endplay should be adjusted with the flywheel.
[Reply]  [No Email]
John Shanahan
02-15-2013 16:49:40
174.231.148.219
 Re: JS 60 Clutch in reply to Maark, 02-15-2013 10:49:26
I had the crank out and put new thrust washers on both side. Crank float as measured with a dial indicator is 0.005". How do you adjust end play different?
[Reply]  [No Email]
gtx1967jewison
02-16-2013 07:47:21
174.225.133.176
 Re: JS 60 Clutch in reply to John Shanahan, 02-15-2013 16:49:40
That is correct. Spec is 0.005" -0.010" so your as tight as you'd ever want.
[Reply]  [No Email]
ET
02-15-2013 09:30:27
50.122.165.79
Your pulley brake is incorectly ajusted. It's alowing you to pull the lever back far enough to re-engage the clutch. With the tractor idling and the clutch disengaged turn the brake ajusting screw in till the pulley quits coasting.
[Reply]  [No Email]
John Shanahan
02-15-2013 04:03:11
98.215.108.119
When I adjusted the clutch, I started with the lever in the engaged position and the clutch loose. Take up the bolt until it just engages. Dropped the lever back it free wheels, pull the lever back and the pulley brake engages. When I start the engine, the clutch locks up with the lever back. The pulley brake will engage the pulley, but can't stop it.
[Reply]  [No Email]
Rick deere
02-14-2013 18:31:24
67.231.40.38
adjust the 3 bolts with the lever forward , than adjuct the brake pulley'
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
