front wheel bearing kits
rytre
want to put new bearing kits in front wheels of 35 unstyled B. Could you please give me advice on where you get these kits from. thanks
Take origs out, they are numbered - check DEERE as i am sure they would have , BUT also run NUMBERS at NAPA and see which is the cheapest,be surprised sometimes DEERE is cheaper, get FELT dirt seals at DEERE. The steel inserts that hold the FELTS can more than likely be reused.
Looks like the outside bearings JD7209 are 14.25
inside bearing JD7222 are 17.25
Outside bearing cup JD7259 are 12.10
Inside bearing cup JD7266 are 7.75
Felts B90 R are 6.84
these are the prices from John Deere
