Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 3010 diesel 24 volt system
Superhornet
02-12-2013 15:54:23
It has 2 12 volt batteries and each read about 12.7 volts and about 25.5 volts across the series. Should the negative on one battery go to the solenoid and the positive on the other battery go to the post on the side of the starter as the book shows, ( mine is the opposite ) or does it not matter?
Tx Jim
02-13-2013 03:44:50
 Re: 3010 diesel 24 volt system in reply to Superhornet, 02-12-2013 15:54:23
Superhornet said: (quoted from post at 18:54:23 02/12/13) It has 2 12 volt batteries and each read about 12.7 volts and about 25.5 volts across the series. Should the negative on one battery go to the solenoid and the positive on the other battery go to the post on the side of the starter as the book shows, ( mine is the opposite ) or does it not matter?
I think reversing the positive & negative cables on the starter shouldn't affect cranking but could affect the operation of accessories such as fuel gauge. I think if generator is polarized either way it will charge the system.
This post was edited by Tx Jim at 03:49:36 02/13/13.
55 50 Ron
02-12-2013 18:34:53
As I mentioned below, I'm not an expert on the new generation 4 and 6 cylinders so best not to give you wrong advice.
Tx Jim
02-13-2013 03:48:05
 Re: 3010 diesel 24 volt system in reply to 55 50 Ron, 02-12-2013 18:34:53
Ron
IIRC except for 2 cyl 24V systems having four 6V batt vs two 12V on New Generation there's not a lot of difference between the two 24V elect systems.
