37 A valve guide
Mark Poss
Can you still buy a valve guide for a 37 A and how do you install it, I am sure you would have to take it to a machine shop to have it pressed in and pressed out. Thanks for any help, Mark.
H&j machine in carrington nd has them for $15 each. They have every valve, guide, valve spring & even seats for every 2 cylinder. ALL of them. Ponys too.
Should I be able to compress the valve spring with one hand and take the keepers out? Or do I need to replace the springs while i have this apart. Thanks, mark.
You can depress the springs with your hand. Not too hard to do. I always put a machine washer under the spring when I take one apart. Commonly found in those large selections at your local farm or hardware store.
