JD bale thrower ?
It was said on the implement forum that a Deere bale thrower can trip after the pump stops turning becase of stored hyd pressure. I always thought that a Deere thrower can not work if the pump is not turning.We are refering to the hyd. thrower like a 30 used on a 336.If I am wrong then I need to be more careful around mine.Thanks Tom
There is no stored pressure on a Deere bale thrower. It is an open center system therefore when the pump stops turning there is no oil flow or pressure.
