| John Deere Tractors Discussion Forum |
Topic: Duplex Carb on a Model B
[Return to Forum]
| Author |
[Modern View]
| JGC
02-12-2013 06:52:15
67.8.21.168
Can a Model B be modified to use a duplex carb, as used on later generation JD tractors?If yes,,,, what is involved; carb, linkages, manifold, head, other components that need to be moved or modified, etc, etc??? Regards, JGC |
| buickanddeere
02-15-2013 08:16:27
184.151.61.232
Re: Duplex Carb on a Model B in reply to JGC, 02-12-2013 06:52:15
| Cheaper and run better, have live hydraulics plus the option of live pto and optional PS if you just trade the B for a 50 or 520. |
| jd b puller
02-14-2013 15:19:00
65.190.129.111
| Agree with most of the comments. Not sure how it would be easier to tune as all the duplex carbs I've seen have fixed load jets with that single screw at the bottom that has very little impact on mixture. My experience with taking a 2 barrel carb, and modifying the manifold to adapt it to a single barrel Head was that it worked ok at wide open but will lose all bottom end unless the motor is really big. The 50 head has 10 head studs, the B has 9 and not in the same location. You can put a 50 block into a B with a little work.What goals are you trying to accomplish? |
| jd b puller
02-12-2013 21:08:50
65.190.129.111
| 2-banger
02-12-2013 18:10:49
69.205.118.226
| you need a 50 hd..manifold and carb..50 hd feeds each cyl seperate where the orginal b hd only has 1 intake port both cyls draw from it.it will make a little more power and be easy to tune |
| gtx1967jewison
02-12-2013 20:45:22
174.254.240.71
Re: Duplex Carb on a Model B in reply to 2-banger, 02-12-2013 18:10:49
| Imo a single carb is easier to tune. Especially a dltx v.s. a duplex. All my singles idle nicer & slower than most duplex tractors at the shows. Half as much to go wrong & if it plugs you can actually access the ports to clear them. |
| Mike M
02-13-2013 07:38:45
24.140.0.120
Re: Duplex Carb on a Model B in reply to gtx1967jewison, 02-12-2013 20:45:22
| I would imagine that most of those with the duplex carbs. have not been adjusted correctly. Like you said they are harder to tune. You need to short out each cyl. and adjust each cyl.to idle at the same RPM. |
| Mike M
02-12-2013 07:37:44
24.140.0.120
| Only thing gained is a better idle. Not really any HP differance between a model B and a 50 |
| John T
02-12-2013 07:31:06
71.52.99.130
| | Not that Im aware of....Its the MANIFOLD thats important, I think the duplex carbs and duplex mainfolds have seperate chambers for each cylinder while the old single barrell manifolds dont. Thats why at slow idle (on single carbs and manifolds) if you pull one plug wire it almost dies while if you pull the other one it dont seem to make much difference NOT SO on duplex carbs with a seperate carb barrell and manifold chamber for each clinder....... Am I correct???? John T |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
