Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Generator still won't charge!
[Show Entire Topic]  [Return to Forum]
M-MAN
02-12-2013 04:25:28
184.39.54.138
John T;
From the previous post this genny put out 40 amps on the test bench. The rebuilder had to have used 12v components and high speed to get that many amps. I think that's why it takes 12v to motor test it. Since a genny is only concerened with amps shoulden't it still charge a 6v?
[Reply]   [No Email]
John T
02-12-2013 05:06:33
71.52.99.130
 Re: Generator still won't charge! in reply to M-MAN, 02-12-2013 04:25:28
Yep this whole thing seems screwed up IT SHOULD MOTOR FINE AT 6 VOLTS UNLESSSSSSSSSSSSSSSSS
as you mention it either has 12 volt fields accidentally installed OR IM STARTIN TO THINK THEY ARE WIRED WRONG OR REVERSED
YES a true proper wired 12 volt genny can easily charge a 6 volt battery YES its more a current source then a voltage device
The armature dont matter as much so if hes wired right Im still back to a genny problem like miswired or wrong field windings
John T
[Reply]  [No Email]
JohnDeereM50
02-12-2013 05:02:41
68.210.13.115
No telling how fast that machine was turning, he didn't know how fast it was turning either. He even eventually admitted he didn't know much about six volt systems.
Still has to be something wrong since it spins one way during motor test and then starts spinning another way when I remove the jumper from ground to field.
I can't take it apart it has a tamper proof seal on the back and if I take it apart he said warranty is void. I'll take it to him and see what he says.
Before you know it spring will be here and I want to take it to some plow days. Time is running out.
[Reply]  [No Email]
John T
02-12-2013 05:13:28
71.52.99.130
 Re: Generator still won't charge! in reply to JohnDeereM50, 02-12-2013 05:02:41
The direction of current through the fields affects the North/South MAGNETIC Polarity (which determines + - ELECTRICAL Polarity and if wired right one side becomes a North Pole and the other side a South Pole. One end of first field to a brush,,,,,,,,splice in the middle,,,,,output of 2nd field to FLD post.
Assuming shes wired right and all else is okay????? I STILL SAY THE GENNY ISNT RIGHT REGARDLESS WHAT HE SAYS (Fields, Field wiring, Field orientation)
John T
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
