TractorLinks.com
Show Parts for Model:
Re: JD 4430 Hydraulic SCV Valve Question
WTW
02-11-2013 20:53:04
Sir, Along with resealing the couplers with a seal kit, replace the springs and keepers on the outlet control levers. These are the levers that you spoke of. The springs on the outlet levers is what holds the lever in the latched position. In addition to the springs also add latch kit/plate to bottom of SCV outlets if it does not already have them. The latch plate is held on the bottom side of outlet casting by the same bolt that is used to retain the dust covers. The original lever stop iron/bracket is replaced with new latch plate and will give a better area/contact surface for lever to latch behind when lever is turned to hold hoses. Good Luck, DW
Tx Jim
02-12-2013 04:54:48
 Re: JD 4430 Hydraulic SCV Valve Question in reply to WTW, 02-11-2013 20:53:04
If I had a male tip that popped out of the breakaway coupler I just took a screwdriver and bent the retaining clip(parts key #30) down a little that WTW referred to.
AR82570 BREAKAWAY COUPLER kit ADD 24.46 USD
