| John Deere Tractors Discussion Forum |
Topic: 3010 diesel 24 volt system
[Return to Forum]
| Author |
[Modern View]
| Superhornet
02-11-2013 16:22:18
70.192.198.138
I have an early 3010 diesel and it is hard to start as it does not crank over very fast and batteries dont stay charged. Starter and generator have been rebuilt installed new cables. I borrowed an old tech manual from a dealer and rang all the wires and found out the batteries are connected backwards according to their schematics. Their 3010 and 3020 all show solenoid to negative, positive to other battery negative either thru tractor frame or a separate cable and positive to side of starter stud. Mine is opposite. Is their book incomplete, what would happen if I switched it? Battery voltage rises when its running to appx 12.7 volts. |
[Reply] [No Email] | |
| ET
02-12-2013 05:07:05
134.179.104.127
Re: 3010 diesel 24 volt system in reply to Superhornet, 02-11-2013 16:22:18
| If you don't already have the jumper cable between the batteries get it. Along with that you need a fuse wire to ground the 12v side of the system. If you have any of those quik fix add on cable ends get rid of them and put on the right cable. You have high resistance someplace. After you try and start it look, touch and smell for something hot. When you touch it may be real hot. Guess how I know? |
| FBH44
02-12-2013 03:53:36
64.85.216.135
| I have a different color tractor, but I found running current thru the chassis really slowed down the starter. Did away with that, and ran cables directly from battery to starter, and BIG difference. |
| Tx Jim
02-12-2013 04:43:33
67.142.163.23
Re: 3010 diesel 24 volt system in reply to FBH44, 02-12-2013 03:53:36
Here's a correct wiring diagram. It's possible the 2 flat braided batt cables have been replaced with one cable attaching both batteries together. You could also entertain installing a hyd de-stroking screw if your 3010 doesn't have one.
This post was edited by Tx Jim at 04:45:00 02/12/13. |
| 55 50 Ron
02-11-2013 20:58:42
209.131.231.73
| The 24 volt system has "floating" lines between the generator and starter. It doesn't use chassis as a current path for the 24 volts. So it sounds like something is connected wrong. These are difficult systems to understand and repair. Where are you measuring the 12.7 volts? And do you have two 12 volt batteries or four 6 volt batteries. Somewhere you should be measuring 27 or 28 volts when it's charging correctly. If you have two 12 volt batteries and you are measuring across one battery, even 12.7 volts says the system isn't charging like it should. Provide more information please.I've heard people say Deere made a big mistake with this design. |
| Superhornet
02-12-2013 15:54:23
70.192.204.29
Re: 3010 diesel 24 volt system in reply to 55 50 Ron, 02-11-2013 20:58:42
| It has 2 12 volt batteries and each read about 12.7 volts and about 25.5 volts across the series. Should the negative on one battery go to the solenoid and the positive on the other battery go to the post on the side of the starter as the book shows, ( mine is the opposite ) or does it not matter? |
| Tx Jim
02-13-2013 03:44:50
67.142.163.26
Re: 3010 diesel 24 volt system in reply to Superhornet, 02-12-2013 15:54:23
| Superhornet said: (quoted from post at 18:54:23 02/12/13) It has 2 12 volt batteries and each read about 12.7 volts and about 25.5 volts across the series. Should the negative on one battery go to the solenoid and the positive on the other battery go to the post on the side of the starter as the book shows, ( mine is the opposite ) or does it not matter? |
I think reversing the positive & negative cables on the starter shouldn't affect cranking but could affect the operation of accessories such as fuel gauge. I think if generator is polarized either way it will charge the system.
This post was edited by Tx Jim at 03:49:36 02/13/13. |
| 55 50 Ron
02-12-2013 18:34:53
209.131.231.73
| As I mentioned below, I'm not an expert on the new generation 4 and 6 cylinders so best not to give you wrong advice. |
| Tx Jim
02-13-2013 03:48:05
67.142.163.26
Re: 3010 diesel 24 volt system in reply to 55 50 Ron, 02-12-2013 18:34:53
| Quoting Removed, click Modern View to see
Ron
IIRC except for 2 cyl 24V systems having four 6V batt vs two 12V on New Generation there's not a lot of difference between the two 24V elect systems. |
| 55 50 Ron
02-12-2013 15:22:20
209.131.231.73
| Sorry. I was thinking of the 2 Cylinder models with 24 volt electrical. Disregard my incorrect info. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
