6 Bolt JD front wheel rings
I was wondering if anyone knows where I can find a set of the after-market rings that were put on 6 bolt JD wheels for support when you used a loader, helped keep from breaking wheels and hubs. BTW, what were they called?
Thank you,
Charlie
I got a set off a junk combine. Check your local combine boneyard. Lots cheaper than new. Take the studs as well. The reinforcement rings I got were not tapered for wheel studs.
