TractorLinks.com
Show Parts for Model:
620 Compression
RMOMN
02-09-2013 15:32:14
What should the compression be and what is considered OK?
BushogPapa
02-10-2013 12:35:11
 Re: 620 Compression in reply to RMOMN, 02-09-2013 15:32:14
Usually best to check it on a couple different occasions..you never know if you might have a little chunk of carbon trapped under a valve that could be temporary..
Pretty sure mine is around 125# in each one..
Can handle 4x16" in 2nd in some hard-pulling ground..when properly weighted..
Ron..
RMOMN
02-10-2013 07:31:43
My 620 has 90# on both cylinders I was told the tractor hasn't been used in over 10 years. I'm going to plow with it and see how it does
johndeeregreg
02-09-2013 17:51:12
we have one with 100# in the left hole and 75# in the right hole and it runs good. the other one we have is sone where between 100 and 125# in each hole,dont remember the exact number now but that one was the same on each side if i remember right, it also runs very good
Gene Hillman
02-09-2013 19:59:07
 Re: 620 Compression in reply to johndeeregreg, 02-09-2013 17:51:12
Well charged battery, both plugs removed, throttle and choke wide open, accurate gauge. Eveness is more important than the reading but should be within 10 percent of each other.
