TractorLinks.com
Show Parts for Model:
Re: 29 D gas tank hood puzzle ????
Mark-Ia
02-08-2013 10:53:00
Meant to type a 29D
Crazy Horse
02-08-2013 11:01:55
 Re: 29 D gas tank hood puzzle ???? in reply to Mark-Ia, 02-08-2013 10:53:00
Great photos, thank you. That's what we have, the same brackets as in your photo. Because the "hold down clamps" (or whatever part they have for holding down the hood which holds the tank)are missing, all we have is a photo of another '29 D that uses sort of a bent iron clamp that bolts to the support bracket. As the bolt is tightened, the clamp pivots and pulls the hood down tight. But the ones in the photo we have bolt to the support bracket inwards about 2" or so, not on the outside like in your photo.
Can you post a picture of those clamps (or whatever system is used to anchor the hood downwards)? I suspect that somehow we might have either the wrong tank or the wrong brackets (and are missing the clamp parts).
Mark-Ia
02-08-2013 11:22:03
 Re: 29 D gas tank hood puzzle ???? in reply to Crazy Horse, 02-08-2013 11:01:55
This is a original hood from a 29D. It uses small slotted angle brackets to fasten to the tank mount brackets. Bolts through the hood brackets and then to the tank mounting bracket.
Crazy Horse
02-08-2013 11:32:49
 Re: 29 D gas tank hood puzzle ???? in reply to Mark-Ia, 02-08-2013 11:22:03
Ah, that's what I wanted to see, something is mixed up here on this end. I'm guessing that we have the wrong brackets for the tank and hood we have. As I mentioned, I think this tank is wider and shallower in height than yours, you didn't mention any measurements but that's what I'm guessing. There is definitely another system used for holding the hood down than yours, at least according to this other photo my friend has. Looking through a JD book here, the photos show the hood with the slots and hold down brackets sticking through (which I described).
Mark-Ia
02-08-2013 11:38:34
 Re: 29 D gas tank hood puzzle ???? in reply to Crazy Horse, 02-08-2013 11:32:49
That style hood with the holes in the side are for ser# 30400-68879. The hood pictured is ser# 91488, built 8-21-29 Shipped to Shelby Iowa.
Mark-Ia
02-08-2013 11:43:46
 Re: 29 D gas tank hood puzzle ???? in reply to Mark-Ia, 02-08-2013 11:38:34
Gas tank is 26" long x 23 3/8" wide and 11" tall
Crazy Horse
02-08-2013 15:49:14
 Re: 29 D gas tank hood puzzle ???? in reply to Mark-Ia, 02-08-2013 11:43:46
Not exactly sure of a measurement but this tank is quite a bit less than 11" in height. Obviously, when your tractor showed up on the scene, JD had increased the tank capacity with a deeper tank, and then had to drop the height of the brackets (lower) which supported it, and at the same time they simplified the hold down hardware of the hood tin and went with some L-brackets spot welded to the inside of the hood. I'm guessing that your hood tin has a greater side height than the earlier ones with the slots in the side.
So what we have here is a JD D with the newer support brackets and the older tank and hood. So we need the older supports and the hold down clamps that are used for the older hoods with the side holes.
Thanks for all the help.
Mark-Ia
02-08-2013 16:13:43
 Re: 29 D gas tank hood puzzle ???? in reply to Crazy Horse, 02-08-2013 15:49:14
If you're going to use the tank and hood that you have, it's not correct for a 1929 D. You need a different tank and hood to be correct..
Crazy Horse
02-09-2013 06:12:47
 Re: 29 D gas tank hood puzzle ???? in reply to Mark-Ia, 02-08-2013 16:13:43
So the changeover was done during the '28 production year then at s/n 68879. And yes, you're right about what we need here to make it "correct". Someone along the way with this tractor has obtained or ordered parts that didn't match up to what is supposed to be on the tractor. I've been told it is a '29 (I've got to check the serial number) with the correct support brackets but the wrong (older style) hood and smaller tank (like you say). Cheapest and easiest way would be to find a set of the older support brackets & hold downs and go with that even though it wouldn't be spot on for correctness for a 1929 (if it is a 29). Thanks again for all the help.
