Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Help adjusting 730D pony
Blksmok
02-07-2013 19:07:31
Tyler...you need to remove the float bowl assembly to get that broken jet out. Rebuild kits are available from JD. Make sure you have a good phenolic (dark brown) float. There are not a lot of serviceable parts in these cabs. Not sure where you'll find the broken carb jet/tube.
raklet
02-07-2013 19:51:40
 Re: Help adjusting 730D pony in reply to Blksmok, 02-07-2013 19:07:31
Today must be my lucky day. I tried tapping the tube out from either end and it would not budge a bit. I was thinking I would have to go source another complete carb, so on a long shot, I took a small drill bit and started drilling into the center of the idle jet. After a few seconds, the whole thing popped out. The outer tube that it slides into (what is it called, btw?) appears to be okay.
www.robertscarbrepair.com has a repair kit and also appear to have an idle jet available as a separate part. I'll call tomorrow to see what's in stock.
This post was edited by raklet at 19:52:48 02/07/13 2 times.
Copyright © 1997-2015 Yesterday's Tractor Co.
