Simply pull it up out of the valve cover.There is an o-ring inside the fitting on the valve cover.Becareful not to beat on the end below the frame rail as it will swell and not come thru the hole.Do not ask how I learned this.
Yes Tom and they swell easy,,If it"s real tight I some times cut them off and put a splice hose on them...
