I would appreciate some advice on getting my 730D pony running better than it is. It will not run at all when the lever is in the start position and will only run in the run position with the choke lever about half way (but needs constant adjustment to keep it going).
The pony dies within a few seconds of engaging the flywheel, but on the bright side, the main does fire with those few turns that it gets.
I suspect carburetor adjustment issues and have tried searching for instructions on adjusting it, but I only ever find "follow instructions in the service manual".
I know there are other threads out there that give basic instructions for other models / tractors, but I'm ashamed to admit that I'm young enough to hardly even know what a carburetor is. I need a little hand holding to get started.
Thanks in advance,
Tyler
Thanks in advance,
Tyler
