Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Help adjusting 730D pony
02-07-2013 14:28:01
Tyler...#34 has a very small hole perpendicular to the tube. It near the front of that part. Make sure it's not plugged. The "original " coils were white and kind of waxy. Replacement coils are usually black. The real shiny ones are foreign made,,the dull black ones are U.S. made..generally. The best way to check your coils is to take a new spare spark plug, detach number 1 plug wire, hook it to your spare plug, ground that plug to the engine, crank the engine and you should have a snappy blue spark. If you have spark on #1 you will also have spark on #3 as both plugs fire off of the same coil. Both plugs need to be grounded to run this test. Repeat this procedure on #2 plug to see if your other coil is good. No spark can be due to bad coils, faulty ignition switch or loose/dirty wire connections.
