TractorLinks.com
Show Parts for Model:
drive wheels lock on 2630 in cold weather
Jim Stordahl
02-07-2013 14:08:54
During cold winter weather, one of the rear wheels on my JD 2630 will lock up as if I stepped on the brakes. It happens to one side or the other, but not both at the same time. It only happens during cold northern Minnesota weather - 20"s or below. The tractor is parked inside an unheated, but insulated garage. When I back it out, it"s fine, but after I drive for five minutes or so (to move snow, etc) one of the rear wheels will "lock up". After letting it sit for a while, I"m able to nurse it back to the garage. If I run the garage heater and warm it up before using it, it does not happen. When it does lock up, I cannot move the brake pedal, it seems to have pressure pushing it into the "off" position. Any clues?
Thanks
Jim
jjtractors
02-07-2013 17:18:35
 Re: drive wheels lock on 2630 in cold weather in reply to Jim Stordahl, 02-07-2013 14:08:54
I had a 2630 that did the same thing, changed the oil, still did it, sold the tractor and about a year ago I read on a site that the brakes have a pocket that will hold a small amount of water and freeze, they said to drain the brake valve in question, wish I had known that before I sold it, the local Deere dealer did not know anything about such a thing. Hope this helps you!!
bmiller36
02-07-2013 16:54:17
change your hdy oil,your problem will be over. Bob
Tx Jim
02-07-2013 15:38:38
Any chance there's moisture in the hyd oil? Have you ever checked hyd filler cap breather to be sure it's free of dirt?
Jim Stordahl
02-07-2013 17:45:20
 Re: drive wheels lock on 2630 in cold weather in reply to Tx Jim, 02-07-2013 15:38:38
Thank you all, for such great suggestions! I will follow your advice and see what happens.
Thank you!
Jim
