TractorLinks.com
Show Parts for Model:
Re: 420 hydraulic remote not working.
gamehunter56474
02-07-2013 11:25:58
One other thing when I first looked at it the Touch O Matic wasn't working either, after determining there was almost no oil in it I put a couple gallons.
Tx Jim
02-07-2013 11:43:55
 Re: 420 hydraulic remote not working. in reply to gamehunter56474, 02-07-2013 11:25:58
If the T-O-M doesn't work then it's no surprise that the remote valve doesn't work either. I think you need to get a gauge and check for pressure.
Gamehunter56474
02-07-2013 16:24:46
 Re: 420 hydraulic remote not working. in reply to Tx Jim, 02-07-2013 11:43:55
I should have specified the TOM works great now
buickanddeere
02-07-2013 19:54:56
 Re: 420 hydraulic remote not working. in reply to Gamehunter56474, 02-07-2013 16:24:46
The TOM is downstream of the scv . As long as the scv is in the middle/neutral position. The oil should flow unrestricted through the scv valve and to the TOM. Having the wrong hose tips is a real possibility . There is still the issue with the relief valve inside the scv body that is not opening to limit system pressure to approx 1040 to 1080psi. Don"t be hissing around with the thing until the scv valve is properly built and calibrated.
