Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Piston wrist pin snap rings for an A
Jason S.
02-07-2013 05:59:03
I looked them up on JDParts.com and for my tractor they show to be obsolete. The originals that came out were worn pretty good where the wrist pin had rubbed up against them.Is there anywhere that the snap ring is available by its self anymore? I thought about measuring them and just getting a modern internal retaining rings and using them. Do you see a problem in doing that? Thanks.
larry baker
02-07-2013 13:33:53
 Re: Piston wrist pin snap rings for an A in reply to Jason S., 02-07-2013 05:59:03
If I'm not mistaken the cast piston and the alum. take a different snap ring,one fat the other thin
Jason S.
02-08-2013 08:22:19
 Re: Piston wrist pin snap rings for an A in reply to larry baker, 02-07-2013 13:33:53
These are cast pistons
fredsjdb
02-07-2013 09:38:19
Try D2824R that"s a 60 snap ring. Good luck. Fred
Pete in MD
02-07-2013 09:37:28
Jason,
If your A is a '40 to '52, the p/n for the snap rings you need is D2824R.
Check JDPARTS w/ this p/n and you'll see they're available for about $6.50 each. Near the bottom of the page is a drawing of the ring with all dimensions noted. With this info you could shop around locally if you think $6.50 is too steep.
Pete
Jason S.
02-07-2013 10:43:04
 Re: Piston wrist pin snap rings for an A in reply to Pete in MD, 02-07-2013 09:37:28
I never thought about looking at a 60. Thanks for the help.
Mike M
02-07-2013 07:19:15
I would try a call a dealer on these. Hopefully you get a good one that will check for sub numbers and also run it on the dealer locator as then you may find some new ones laying around somewhere.
machinery-man
02-07-2013 06:34:06
There should be plenty of these on the used market. Modern rings may not be the same width but if you can get a retainer in the same width I would see no issues. I suppose you could even use several narrow rings as long as your width does not bind the pin. But personally I"d just get some used one...check ebay or several of the used salvage yards this is a common part....
Jason S.
02-07-2013 08:22:49
 Re: Piston wrist pin snap rings for an A in reply to machinery-man, 02-07-2013 06:34:06
On the part number for the snap rings it has a D in front of it. Does that mean discontinued? I also checked depotparts and they have none also. I thought finding new ones would be easy as many of those tractors are around. I keep looking on ebay because I wanted to buy new wrist pins also but I cant see paying $132.00 a piece for a wrist pin from the dealer.All i have found so far is unstyled pins on ebay.
