TractorLinks.com
Show Parts for Model:
Re: JD dune buggy
Tim S
02-06-2013 18:30:44
That guy is as John Deere nuts as I am,,here is one of my "Street Gators"
Mike M
02-07-2013 13:40:26
 Re: JD dune buggy in reply to Tim S, 02-06-2013 18:30:44
I like it ! Hard to find them not all rotted out though.
Tim S
02-07-2013 16:56:14
 Re: JD dune buggy in reply to Mike M, 02-07-2013 13:40:26
I have a few guys that keep an eye out for good ones,,I only use "good" ones, no rust, I get them with blown engines then put a new re-built one in, I rebuild them here, I buy some rusty ones for parts and engines. I strip them down and take care of the drive line and brakes, instal the cab back and some pieces to fill in body panels in the rear, then I send them to a paint shop and use an automotive Deere New Green paint copy, then I put the strips on using 3m decorative tape, and paint the wheels actual Deere Yellow. I have a metal shop shear and bend the beds, then I weld them up on a set-up stand, I have a Jig made up for the hoist sub frame. for the hydraulics I run a line from the power steering pump to a solenoid direction valve, the the bypass oil down to the steering box,I actuate the valve with a rocker switch in the cab for power up and down (drawing it down on a rubber strip to keep it from rattling),It will dump the bed full of #7 stone, i have a windshield guy put a piece of auto glass and an apolstery shop do the inside rear panel.They are nice when they are finished,,but I don"t make enough on them to make it worth while, i have only done 6 of them..
jd b puller
02-07-2013 08:40:47
probably cost less than a gator too...
I think you should put it on tracks.
Tim S
02-07-2013 10:43:27
 Re: JD dune buggy in reply to jd b puller, 02-07-2013 08:40:47
I was selling them for $8,000, they are 4 wheel drive, very towing friendly 2 speed transfer case, air cond. am/fm radio hydraulic dump bed,and you can go to Auto-zone for your parts,they are fun to knock around in,,I haul one with me to the shows, gives me a ride to the hotel..
scotc
02-07-2013 19:06:39
 Re: JD dune buggy in reply to Tim S, 02-07-2013 10:43:27
I like that. Don't know about the color though. Or that I would use the dump bed much.
