Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: What's the difference between a (6466) and (6076) engine?
[Return to Forum]
4020guru
02-06-2013 16:16:44
216.226.89.76
What's the difference between a (6466) and (6076) engine? I understand they are both 466 blocks and the 6076 came out in the 55 series. Was just curious what the differences are.
[Reply]   [No Email]
Eric Hartman
02-06-2013 20:35:09
184.21.187.96
 Re: What's the difference between a (6466) and (6076) engine? in reply to 4020guru, 02-06-2013 16:16:44
The information that I am citing comes straight from the 60 series tractor brochure. The 6076 engine had a 33 percent torque rise, a higher top ring placement on the pistons, dome shaped combustion chamber in the cylinder head, 7 hole injection nozzles, whereas I think the 466 had 6 holes in the nozzles. There are also noticeable differences in the casting of the engine block, too. I believe the injection pump has an electronically controlled governor on the 6076 and the lack of the aneroid valve. The 6076 does not seem to be nearly as difficult to start in colder weather conditions, and the sound of the engine is quite different, as the engine has a more noticeable and sharper firing/ignition, which I think comes from a little higher compression ratio and the fuel injection system. The 466 in the 50 series, when running sounds like the 466 from the 40 series, whereas the 6076 sounds like the 6081, and I do hesitate to say this, but it does also sound more like the 8.3 liter cummins when running, as compared to the sound generated by the prior Deere models.
[Reply]  [No Email]
skip33652
02-06-2013 18:35:52
68.69.73.24
the 6076 had better fuel economy( look it up in the nebraska tests) revised head, pistons, pumps and injectors. I think bigger wrist pins as well. The gear drive waterpump is better and more durable but can get water into the oil. both are rock solid engines.Paul
[Reply]  [No Email]
Tx Jim
02-06-2013 16:19:44
67.142.163.24
 Re: What's the difference between a (6466) and (6076) engine in reply to 4020guru, 02-06-2013 16:16:44
early 466 has belt driven water pump
late 466(50 series) & 6076 had a gear driven water pump(RE55985)
I think a 6076 has a better air flowing cyl head(part # RE58516)than a 466
This post was edited by Tx Jim at 16:32:12 02/06/13 2 times.
[Reply]  [No Email]
4020guru
02-06-2013 17:22:08
216.226.89.76
 Re: What's the difference between a (6466) and (6076) engine in reply to Tx Jim, 02-06-2013 16:19:44
TX JIM , I have a few qeustions for you , and seem like the guy that would know . I have compared a 4450 to a 4455 and I noticed that the 4450 has an aneroid and the 4455 doesnt. The 55 has a sensor going to the intake manifold . Is the 6076 electronic injection ? Which water pump drive do you think was better ? What kind of water pump drive is in the 8.1L that replaced the 466 ?
[Reply]  [No Email]
Tx Jim
02-07-2013 04:46:06
67.142.163.24
 Re: What's the difference between a (6466) and (6076) engine in reply to 4020guru, 02-06-2013 17:22:08
Easy on the questions. I'm an old timer and they're some "young guns" on this forum that are more up to date than I am. I can tell you for sure my 4255 isn't electronically fuel controlled but it is very good on fuel usage. It has 10,500+ hrs on it without an OH and will rd bale hay using a little over 3 GPH of fuel. My 4255 will crank in freezing weather without the aid of ether or coolant heater(no electricity in the tractor shed). I've owned the 4255 for 20 yrs. I just put the second waterpump on my 4255 @ 10,125 hrs
I know the 55 series with the 6076 engines are some of the best tractors to have the JD logo put on them!!!!!!!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
