TractorLinks.com
Show Parts for Model:
Re: 47A Engine Locked Up
Harvey 2
02-06-2013 08:09:43
I have unstuck a lot of John Deeres; One way I do is take the valve cover off and see if any of the valves are stuck shut, if any are stuck shut loosen the rocker arm so you won't break a tappet when the engine does turn. Next step is get a long pry bar and hook it to the fly wheel and put pressure on it,soak the cylinders with your favorite panther pee and leave for several days, every now and then put more pressure on pry bar till it begins to turn and then rock flying wheel back and forth. One other way is if you aren't in a hurry back tractor up to a tree and jack front end up and hook chain around tree to tractor and leave in high gear, the weight of tractor some times will turn engine. And then sometimes I have had to take engine appart to get it loose
