TractorLinks.com
Show Parts for Model:
Re: M JD Generator
M-MAN
02-06-2013 06:34:26
He converted your genny to 12v. That's why it took a 12v to motor test it. It should still work on your 6v system but I think you will have to use a standard regulator with it. The genny is just putting out amp's. Make a new post to catch his eye and mabie John T can tell you about regulating it.
JohnDeereM50
02-06-2013 16:39:56
 Re: M JD Generator in reply to M-MAN, 02-06-2013 06:34:26
The guy didn't say anything about it being converted to 12v but maybe all the new parts he used is 12v and he didn't know. If this is indeed the case can't I install a 12v battery along with a normal regulator? Still won't charge on the tractor though, I'm gonna take it back off and make sure its grounding good where it bolts to tractor.
M-MAN
02-06-2013 21:29:05
 Re: M JD Generator in reply to JohnDeereM50, 02-06-2013 16:39:56
Yes you could. You would also need a ballast resistor or just change the coil to one that doesn't need a ballast resistor. I prefer the latter. New bulb's in the light's as well.
