Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 1931 john deere GP
[Show Entire Topic]  [Return to Forum]
ecclap
02-06-2013 06:29:22
208.126.149.38
Richard
By glancing at your pictures I don't see anything that doesn't look like regular equipment on a 1931 "GP". There could still be something different about your tractor though. Your one picture shows the fuel tank. Does it have two round holes in it, or does it have a small threaded hole and a larger oval for the fuel? This is one of the changes that happened at 226402 according to the parts books. That's not to say it didn't happen to some earlier tractors.
The most evident changes at 226402 were made to the cooling system and fuel tank. The radiator was made taller to increase cooling capacity. The early radiator sides have a C257R casting number and the sides after the change were C1910R and C1911R. The core and other associated parts were also changed. When Deere increased the bore of the tractor to 6" they must have found out that the cooling system was not up to the task with the extra power and the elimination of the water injection system.
The fuel tank design was, in my opinion, a change made for safety more than anything. The tanks previous to 226402 have a small threaded cap for the gasoline portion of the tank and a large oval opening for the main fuel tank. The main tank takes the same cap as the radiator. This designed started with the first "D"s that came out. I believe the oval opening was to allow fuel (kerosene, tractor fuel, etc.) to be poured out of a bucket without using a funnel. The new fuel tank had the familiar round caps that were used on all of the later tractors.
The most important addition to the fuel tank was the addition of a heat shield like one of the previous posters stated. This consisted of two pieces of sheet metal with and "air gap" in between them spot welded together. This shield sat underneath the fuel tank. Sandwiched between the top of the shield an the tank was a sheet of asbestos insulation. This whole assembly was to prevent engine and manifold heat from boiling the fuel in the tank which was a safety and performance concern. I have personally witnessed an early 6" bore "GP" without these updates, boiling the gasoline in the sediment bowl. Talk about scary! The tank on the early tractors sits very close to the manifold and engine and working the tractor hard would tend to have this effect.
Other minor things were also changed at 226402 but they are mostly internal such as the pistons. One other thing you might want to check is the casting number of your final drive housings. This is located right below the brake drum. The housings were changed to the final design at 225841 so that is another possibility for an update to your tractor.
[Reply]   [No Email]
Richard wyld
02-07-2013 19:11:05
69.31.202.35
 Re: 1931 john deere GP in reply to ecclap, 02-06-2013 06:29:22
well did some more looking and the the rad is updated but hard to tell on the final drives,the numbers are hard to see, the fuel tank has two bigger holes in it, but did find any heat shield. again sorry for the bad pics. so i take it this tractor was at one time probably a small bore ? and then updated to big bore hence the A on the serial # to keep tract of it from JD or the dealer. again thanks for your help on the topic of the GP, it is in very good shape and everything is there so it is for sure a keeper, who knows some day somebody else mite spot something on it or know more about it. thanks very much !
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
