TractorLinks.com
Show Parts for Model:
Re: 47A Engine Locked Up
husker44a
02-05-2013 22:22:32
Its not in gear and the clutch engaged is it ? Assuming not. Remove the spark plugs and make sure its not locked up from a leaking headgasket. Crank it over to check. If still no go. You can remove plugs and pull it with another tractor or vehicle engaging the clutch lightly to break it free. If still no go you'll have to remove the head, block. I've never seen or heard of one sticking over a few months time. Good luck.
Mike n Mo
02-06-2013 05:00:50
 Re: 47A Engine Locked Up in reply to husker44a, 02-05-2013 22:22:32
Husker, I bought a "B" that stuck over a weeks time. I looked at the tractor, it turned over easy, but didn't run. I went back a week later to get it, and it would NOT turn over. We put it in high gear and rocked it some to pop it loose. It was stored inside as well. So outside with the stacks uncovered is just a stuck engine waiting to happen. Mike
