TractorLinks.com
Show Parts for Model:
Re: Mounting more lights on a 8640, want to do it right !!
Mike Aylward
02-05-2013 19:28:26
On all my tractors I add four lights up front, all wired on a separate circuit coming from the starter. I use a 50 amp breaker sending current to a 50 amp toggle switch with heavy wire going to a relay. This sends the current to the front lights (also drawn from the starter). The lights up front are two 4509 aircraft landing lights (spotlights) in the center and round halogen lights pointing outward to the next swath. When properly aimed you can see a marker track across a quarter mile field easily. I did this on one tractor years ago and it worked so well I've done it on two more. They are mounted right above the front weights so the light pattern is flat. This setup works very well and doesn't break the bank, either. Mike
