Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: alternator wiring - 52 A
[Return to Forum]
young gun
02-05-2013 13:54:33
174.54.161.52
wondering if someone can help me determine wether I have the correct wiring for the alt on my A. it wasn't charging my battery at all before I tore everything apart; alt is currently at the shop being tested/fixed (if necessary) so figured I would make sure wiring is also correct.
- there were 2 wires coming from the alt; one went to the switch for the lights and the other went to the amp guage...
- from the amp guage (besides the wire to the alt), there was one wire that went to the on/off switch, and the third wire went back to the battery on the negative pole (tractor is positive ground)...
if anyone knows if (A) this is correct and (B) what poles on the amp guage and alt should be sending wires in which direction (in case they are switched) please help me out.
thanks
[Reply]   [No Email]
rvirgil_KS
02-05-2013 15:14:46
50.93.224.249
 Re: alternator wiring - 52 A in reply to young gun, 02-05-2013 13:54:33
What alternator do you have?
A commonly used alternator is the Delco-Remy, which from the factory was negative ground. (It is possible to have one that has been modified for positive ground.) If you tried to install a negative ground alternator on your positive ground tractor it will immediately fry the alternator.
If you have the common Delco alternator the wiring would be:
#2 on plug to large out put stud
#1 on plug to output side of ignition switch with a diode, resistor, or idiot light in the line.
Output stud to one side of ammeter. Light and ignition switches also go to this side of ammeter.
Other side of ammeter to hot battery post.
If you need to switch to negative ground, ignition coil -- (if it has distributor) goes to side post on distributor.
Connect ammeter so it reads negative with lights on and engine not running.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
