2150 no power steering
The farm hand was using the tractor all day. He parked the tractor for the day the next morning he started it up and no power steering where should i start looking for the problem. Any info and pics would be very nice. Thank you very much.
Do other hyd functions operate properly?? How long since hyd filter was changed and sump screen cleaned? Then I'd suggest to remove check valve(parts key #2) and try steering.
If it was something on inside of PS housing parts keys #19 & 23 are the control valves and both would have to malfunction to have NO steering.
How is the fluid level?
Simple I know, but I have a 310 backhoe with a very similar steering valve set up. If I have a loss of steering it has been fluid level.
