JD 4010 gas oil leak
Donny S
New User
I have a 61 JD 4010 gas that I recently acquired. I have only used it maybe 2 hours since I got it home. I got it from a friend who was using it every day. I Went to start it today and its pouring oil out the exhaust and out the air intake to the Carb when I pulled it off the Carb. I pulled plugs and seen oil on them. I don't understand how this became an overnight problem.
Sounds like the carb is leaking. Was the fuel tank full when you parked it? A leaking needle valve or sticking float in the carb can fill the intake with gas.
