steering adjustment
mlbtex
hey my 730 with power steering wants to go right. it just sitting there at idol will turn all the way to the right on its own. im trying to figure out where the adjustment is on the pump. anyone out there know
Take the nosecone off and losen the four bolts holding the steering valves on slightly and gently tap it either forwards or backwards and that should solve your problem. Goes best with two people, one with a hammer and one in the seat.
You might try borrowing a dial indicator to keep track of how much you are moving it...I found on my 70 that incredibly small movements fore or aft had a very great impact on whether it wanted to turn left or right!
well the small movements lead to great response is correct. i barely tap it and it would go all the way to left and after 20 min of playing with it i thought i had centered. then took down road and still had a pull to the right but at least now just sitting there it dont sharply take off right.
you need to have the front of the tractor off the ground weight must be off before you start tapping to get it strait.
Install a pressure guage in the valve housing and tape the housing back and forth until you get the lowest pressure {90 to 110 psi}
