Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
steering adjustment
mlbtex
02-04-2013 11:45:26
hey my 730 with power steering wants to go right. it just sitting there at idol will turn all the way to the right on its own. im trying to figure out where the adjustment is on the pump. anyone out there know
Chile43
02-05-2013 18:55:44
 Re: steering adjustment in reply to mlbtex, 02-04-2013 11:45:26
Install a pressure guage in the valve housing and tape the housing back and forth until you get the lowest pressure {90 to 110 psi}
rickdeere
02-05-2013 07:17:52
you need to have the front of the tractor off the ground weight must be off before you start tapping to get it strait.
mlbtex
02-05-2013 07:34:19
 Re: steering adjustment in reply to rickdeere, 02-05-2013 07:17:52
ok thanks ill try that when i get home and see if i can get figured out
mlbtex
02-05-2013 07:34:13
mlbtex
02-05-2013 05:42:38
well the small movements lead to great response is correct. i barely tap it and it would go all the way to left and after 20 min of playing with it i thought i had centered. then took down road and still had a pull to the right but at least now just sitting there it dont sharply take off right.
Hugh McKinney
02-04-2013 21:43:18
You might try borrowing a dial indicator to keep track of how much you are moving it...I found on my 70 that incredibly small movements fore or aft had a very great impact on whether it wanted to turn left or right!
Mitch D
02-04-2013 12:55:39
Take the nosecone off and losen the four bolts holding the steering valves on slightly and gently tap it either forwards or backwards and that should solve your problem. Goes best with two people, one with a hammer and one in the seat.
