Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
JD AC , how to retrofit r-12 to r134A ?????
4020guru
02-04-2013 11:17:18
I am planning on replacing the r-12 refer to r134a. I have retrofitted home air conditioning and the question is, what is the process with a 4430? I will evacuate the system, will the compressor need to be changed? How about the expansion valve ? Do they have an expansion valve or a capillary tube?
Bob
02-04-2013 19:55:13
 Re: JD AC , how to retrofit r-12 to r134A ????? in reply to 4020guru, 02-04-2013 11:17:18
A few choices... Keep the original mineral oil refrigeration oil and run a b*u*s*t*a*r*d refrigerant like Freeze 12, or get all the mineral oil you can out of the system and install POE oil and R-134A, or COMPLETELY flush the system of mineral oil, replace the compressor and dryer, and install PAG oil and R-134A. The BEST and Deere-approved method is the latter.
DO NOT mix the original mineral oil and PAG oil. (Can you say "Jello"?)
...Bob, refrigeration tech, certified in mobile and stationary systems.
4020guru
02-05-2013 14:03:48
 Re: JD AC , how to retrofit r-12 to r134A ????? in reply to Bob, 02-04-2013 19:55:13
Hey Bob, what is a BUSTARD refrigerant? Do I have to replace the compressor to get all of the oil out ?
mattwillson
02-04-2013 16:43:21
Just vacuum system really good and load it with r414a, it works well for me.414 isn't much more than r12 and is basically a direct replacement.
BushogPapa
02-04-2013 16:42:34
I have never done anything but charge with R-134, even if some R-12 was still in there..NO Problem.. R-134 does need to run a higher Low-side pressure and I feel it cools better... I have 1/2 a BOTTLE of R-12, if anyone wants to buy it...!!
Ron..
4020guru
02-05-2013 14:04:58
 Re: JD AC , how to retrofit r-12 to r134A ????? in reply to BushogPapa, 02-04-2013 16:42:34
Hey Brushhogpapa, how many OZ. are in your 1/2 bottle ?
BushogPapa
02-06-2013 12:05:59
 Re: JD AC , how to retrofit r-12 to r134A ????? in reply to 4020guru, 02-05-2013 14:04:58
ell, it was, I think a 20 lb bottle..I am sure it is at least 1/2 full..
I could weigh it..
Ron..
mecanik69
02-04-2013 13:26:19
leave it r12 r134a sucks.
Tx Jim
02-04-2013 14:12:58
 Re: JD AC , how to retrofit r-12 to r134A ????? in reply to mecanik69, 02-04-2013 13:26:19
My 4255 cools better on R134a than it ever did on R12.
