sound guard cab parts
coonie minnie
Does anyone know if the side panels- the piece below the fender- is still available from deere? Or anyone else?
I'd like to rehab a cab. I got one a several years ago, but can't find one listed on the the deere parts website. Am I missing something?
These part #'s fit the 30 & 40 series.
RE15078 FENDER ASSEMBLY, LH (PARTS) ADD 918.06 USD
RE15077 FENDER ASSEMBLY, RH (PARTS) ADD 918.06 USD
I think he is referring to the sheet that goes down below the fender, the flat sheet with a few edges rolled into it,,I have never replaced that part before, it is spot welded to the roll frame, he may need to cut out the bad area and get a piece sheared to weld back in..
These are for 30 series-- 1 piece, spot welded on. The 40 and 50 series have 2 piece, the fender on top, and a separate sheet that is spot welded on to the side. It is vertical, although the top flares out at a 45 to meet the fender.
I can't seem to find them listed.
