Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: What year b's had different hoods?
02-02-2013 17:13:20
Well before s/n #201000 (somewhere in 1947) they had the battery up under the hood. After they had a box seat with the bat under seat. The hood you are showing , aside from being in two pieces which they weren't , is off a '47 or newer with bat under seat. Why would you buy a cut up hood? I assume they sent you a front portion with a good uncut exhaust hole to weld onto the rear portion to make one complete as they did not come that way.And what about those makeshift bolt tabs welded on there? Guess I don't understand. Not only do you not have the correct hood for yours but not even a good sellable hood for what it does fit. Live and learn I guess.
02-02-2013 17:52:43
 Re: What year b's had different hoods? in reply to B-maniac, 02-02-2013 17:13:20
Forgot to mention the battery hoods used an entension to the rear of the hood.
Tx Jim
02-03-2013 04:12:59
 Re: What year b's had different hoods? in reply to B-maniac, 02-02-2013 17:52:43
Since you mentioned the fact I remember battery in front of the dash but I see no parts breakdown in the catalog for these parts. I thought I was fairly decent at looking up parts in JD's catalogs but I guess not.
02-02-2013 17:49:23
I got it cheap and it came with a good gas tank I needed I can weld in the patch and fix it up and set it in a shelf for later or sell it cheap.. The piece with the tabs are from the old hood that was on it..
02-02-2013 17:57:04
 Re: What year b's had different hoods? in reply to JohnDeereJimOhio, 02-02-2013 17:49:23
If you can get the muffler hole spacing correct without a (try it out first) tractor then you should be able to get good $$ for it as there weren't many all fuel late "B",s built. Good luck.
