| Author |
[Modern View]
| LonM
02-01-2013 13:52:03
69.165.30.73
We run two 3020 diesels every day for feeding cattle, both have tank heaters for the engine and both have synchro transmissions. They start fine, but the hydraulics really whine and they steer hard when it is this cold out (-20 F). Today for one tractor I put two hydraulic tips on one hose and plugged each end into the SCV and just let it circulate oil through the system while I loaded the feed wagon. This seems to help. Does anyone have any other "tricks" to get that hydraulic system warmed up more efficiently (outside of a heated shop)? Thanks for any discussion! LonM |
[Reply] [No Email] | |
| Fred Gross
02-02-2013 15:36:26
74.204.106.76
Re: Warming up a cold tractor in reply to LonM, 02-01-2013 13:52:03
| Regarding the Amsoil synthetic hydraulic oil. I run it in my JD 2210 CUT. The manual calls for either low or hi viscosity hygard depending on the temps. When i did my 200 hour oil change I switched over to Amsoil ATH and have been using it ever since. The 2210's power steering and hydraulics work great even at -10 or below and I notice no difference in performance other then it works better when it's cold. If I was using a tractor every day in subzero weather I would definitely run synthetics throughout. |
| Johndeere39h
02-02-2013 14:51:07
66.41.113.151
| That part AR98518 there is one on eBay right now for 21.99 with free shipping just did a search for it by that part number if that helps any? Jeff |
| cooney minnie
02-02-2013 12:05:39
166.182.3.202
| Deere recommended the hose trick to warm the oil before using a hydrapush spreader in the dead of winter.... |
| tomstractorsandtoys1
02-02-2013 08:57:37
64.136.27.162
| We have the same issue on our 3020 that is used on our tmr mixer.The hose idea is the best I have found. We tried a dipstick heater but it did not work. |
| LonM
02-02-2013 08:09:12
69.165.30.73
| Thanks everyone for the replies. I don't know if Hy-Gard or its equivelant is available in synthetic or not but I'll look into it. External heat pads look like a good option... LonM |
| Tx Jim
02-02-2013 09:14:20
67.142.163.22
Re: Warming up a cold tractor in reply to LonM, 02-02-2013 08:09:12
| You might try Low-Viscosity Hy-Gard™ |
| 48farmall
02-02-2013 06:58:34
69.161.41.18
| Just an idea- Would something like this work for you? I'm not sure where/if there's a place to put it on your particular tractor. |
| Gundoctor
02-02-2013 05:37:15
68.142.62.73
| How about SYNTHETIC Hydraulic Oil. I have never use it but we keep getting ads for Amsoil. Would this be the answer?? Would this help??? Has anyone put this in your tractor???I would like to know!!!!! It was -30 here last week!! David Pidgeon New Haven, Vermont |
| larryanderson
02-02-2013 04:18:49
184.21.172.50
| On our new 6170 JD loader tractor the cold weather package heats engine ,trans and water which makes it start easy plus the hydraulics work easier.The only problem is when I first got it it would trip the circuit breakers but they fixed it.So I am sure it must use more amperage than with just one function.Plugging them in an hour or more is a lot easier on them but the hydraulic oil at 20 below can be real slow for a while.The oil in the loader cylinders takes a while to get it into system. |
| Fred2
02-01-2013 19:52:45
76.198.253.106
| Deere made a heater that screwed into the transmission case for that need to check with your dealer |
| Tx Jim
02-02-2013 04:15:18
67.142.163.25
Re: Warming up a cold tractor in reply to Fred2, 02-01-2013 19:52:45
| Quoting Removed, click Modern View to see
The part AR98518 is no longer available. Contact your local John Deere dealer for other options.
| chevytaHOE5674
02-01-2013 14:28:11
74.221.60.204
| I have a magnetic heater that I stick on the sump of my hay feeding tractor that I plug into the same timer as the block heater. Really helps on the cold days. |
| Tx Jim
02-01-2013 14:05:03
67.142.163.22
| Back when I worked as service manager for a JD dealer circulating the oil with the scv with a hose with a male coupler tip on each end to get hyd oil warm so a leak would show up better is the way I did it also. Doesn't take a long time in warm weather for oil to get hot. |
